Sonnet questions
    Dougal
    Posts: 77 from 2010/10/22
    My Sonnet G4 1GHz upgrade arrived today. Yayyyy :-)
    I have some questions please.
    1: Is it there another way to upgrade my Power Macs bootroom without having to install crappy OS 9.2 ?
    2: In OS X with the current 466MHz G4, Youtube is really choppy unless i set it to 240P. Will (less than 720P) videos on youtube run perfectly now?
    3: Will i get full speed with ALL games in E-UAE in MorphOS?
    [I know i will have the answers to questions 2 and 3 once the upgrade is installed, but i am curious]
    Regards
    Chris
    Power Mac G4 1Ghz (Sonnet Encore) 640Mb, ATi Radeon 9000 Pro, USB 2.0
    OS: MorphOS 2.6 (Registered) , Mac OS X Tiger 10.4.11
  • »12.11.10 - 10:33
    analogkid
    Posts: 719 from 2004/11/3
    @Dougal:
    1. Yes, install OS 9.1 ;-) But seriously, you have to install OS9.x . There's no possibility to update the bootrom without it. I had the same problem...
    2. Depends on. If you use HTML5, maybe video playback is better in Fullscreen (which uses HW overlay).
    3. I think ECS games should run in fullspeed (with HW overlay display). AGA games could need a frameskip.
  • »12.11.10 - 10:49
    Posts: 12537 from 2003/5/22
    360p should run okay now.
    No.
  • »12.11.10 - 11:24
    Dougal
    I cant do this because OS9 f***ing 9 wont install  :-x
  • »12.11.10 - 14:05
