mos 2.6 on powermac 400mhz no internet
    kickstart
    Posts: 227 from 2009/4/28
    Hi.
    As topic said... installation without any problems on a powermac 3.1 400mhz with ati rage (dont show any graphics garbage like i read on another post) my problem come with the internet connection, dhcp and manual configuration failed and the ethernet card runs with ubuntu.
    Suggest?
  • »12.10.10 - 23:28
    Tiki
    Posts: 21 from 2004/10/4
    Salut,
    I had same problem with my Pegasos and my MDD. Dhcp won't work, so if you have ever try manual configuration, have you think to fill in DNS configuration ? It's the only way that worked for me.
    Tiki
  • »13.10.10 - 03:49
    kickstart
    Well as i wrote dhcp and manual config fails, in manual config mode i fill gateway, local ip, primary and secundary dns... is like no ethernet cable connected, thanks anyway.
  • »13.10.10 - 04:15
    Posts: 3311 from 2003/3/5
    Check which network chip your PowerMac has. Apparently some of the oldest versions use a totally different chip than all other ones. Hard to tell whether it's going to be supported.
  • »13.10.10 - 05:10
    Fred_AROS
    Posts: 18 from 2010/10/11
    Does PCI NICs work then ?
    If so, which ???
  • »13.10.10 - 07:16
    Realtek RTL8139C 10/100MBit
  • »13.10.10 - 07:33
    Simon
    Posts: 809 from 2008/7/6
    I just added RTL_8139D ... I didn't see it had to be 8139C.
    Seems to show up fine in the network preferences but when I put the UTP cable in it does nothing, while it does work when in the Sungem device.
  • »13.10.10 - 15:00
    Ruud
    Posts: 335 from 2009/2/2
    @Oepabakkes
    I have successfully used an RTL8139D in my Powermac G4. I first had to disable the internal NIC in network preferences before it would work however. Hope this is of some help.
  • »13.10.10 - 15:50
    Divinity
    Posts: 512 from 2009/9/8
    @Ruud
    here the same, used an PCI RTL8139D (It's OK in Powermac AGP Graphic and also as second NIC ethernet in FW800 Dual G4@1420)
  • »13.10.10 - 16:24
    Simon
    how to disable the internal NIC, just by deselecting "eth0" in the network preferences ? I acutally did that but still the realtek didn't do anything and when I replaced the cable in Sungem it still had connection. Maybe it needs a reboot ?
  • »13.10.10 - 17:15
    kickstart
    How to see what kind of network chip come with powermac? how to disable the internal network card?
  • »13.10.10 - 17:40
    Ruud
    @Oepabakkes
    I deselected the sungem device, saved, rebooted and the RTL card then worked ok.
  • »13.10.10 - 18:35
    Ruud
    Well hopefully when you open System Preferences -> Network it should be listed under the Network Interfaces tab. If you've only got loopback, your NIC isn't detected/supported by morphos. If it is listed then to disable it uncheck the box next to eth0 and save. If you have an RTL8139 installed that should be listed undeneath as eth1 and will be used instead after a reboot.
  • »13.10.10 - 18:41
    Simon
    I got it working .... still the same problem. Because I am to far from my router, I do internetsharing with windowsXP. Everytime I reboot, I have no internet but I do have network. As soon as I run the internet sharing wizard on XP I also have internet on my MorphOS machine. Not sure why it does that.
    Better get me a second hand ethernet to wifi adapter, so I it doesn't have to rely on the PC.
  • »14.10.10 - 15:46
    pampers
    Posts: 1068 from 2009/2/26
    Is the network card on pci going to work better than internal?
    MorphOS 3.x
  • »14.10.10 - 16:35
    Posts: 607 from 2003/4/11
    I put an special archive under http://www.cybergraphx.de/sungem_ctrl_20101014.lha
    It is some (shell) tool to modify/dump sungem ethernet controller settings at runtime. Maybe some of you who run into trouble find a way to improve network speed that way. Please send output of "sungem_ctrl dump dumpreg" to the email address in the header in any case. It probably helps to identify the problem and provide a proper fix in the future. Please add some info about your network setup as well.
    E.g. you can do
    sungem_ctrl mii 100 hd
    to reconfigure the network to mii mode , 100mbit, half duplex
    while mii is used for 10/100mbit , gmii is required for 1000mbit
    There are some options to enable autonegotiation or restart negotiation as well. Maybe you succeed to find some better settings this way. Run it without any arguments to see the possible arguments.
  • »14.10.10 - 16:56
    Simon
    I will test it. It seems that after all the PCI realtek does work without the need for fiddling with the internet sharing wizard on my pc. So whatever happens, it has something to do with Sungem.device.
  • »14.10.10 - 17:48
    Everblue
    Posts: 170 from 2004/1/6
    My internet seems to be a bit slow with Sungem.device so I am thinking of purchasing a PCI Network card. Will a 8139D do, or it *HAS* to be a 8139C?
    Cheers.
  • »15.10.10 - 07:16
    Posts: 12537 from 2003/5/22
    Considering that at least two different people in this very thread confirmed that the 8139D works for them I think the answer should be clear ;-)
  • »15.10.10 - 07:28
    Simon
    Also an older 8029 with coax and utp was recognized in my Powermac (as a 8139). I didn't really test it, but if you have one around it sure is worth to try.
    [ Edited by Oepabakkes on 2010/10/15 12:38 ]
  • »15.10.10 - 07:35
    Everblue
    OK point taken :)
    I grabbed an SB Live too as sound on my machine is too low for some reason.
  • »15.10.10 - 07:42
    Buzz
    Posts: 5 from 2007/12/10
    Today I Installed mos 2.6 on my free powermac 3.1 AGP.
    When I started the installation morphos did not find my network card.
    I checked in osx and my powermac have a DEC chip 21143, who ar not supported by morphos.
    But I did see that under devs/netowrk drivers that mos support RTL 8139 chip.
    After a quick look in my sparepart drawer I find a unknown manfufature ethernet card with RTL 8139c chip.
    I installed the card and started install.
    Morphos did find my card.. nice.. but then the trouble started...
    I got so far until it was copying files to my system disk.. then I halt..randomly.. from 40mb copy too 110mb copy...
    I removed the card, and installed morphos wihtout it, all files was copy over and morphos was sucssesfully installed.
    installed the card again.. and rebootet.
    did a check and morph still found my rtl card..
    But I could not ping any ipadress. I got link. but no data was transfer true.
    Then I saw the option under "expert" too sett the mac adress for the card.
    Then I rebootet too osx to find that mac adress my uknown rtl 8139c card have.
    Typed in under network-->exspert->hardware adress.
    Now it work great!! :)
    I have network :) and typing this from the powermac.
    just for info.. If any others have that problem :)
    Cheers
    BuzzBrain
  • »09.11.10 - 13:33
    kickstart
    E.g. you can do
    That can be usefull for macmini owners with the but on sumgem ethernet card?
  • »09.11.10 - 14:18
