Catweasel problem
    Yvan
    Posts: 79 from 2003/3/28
    I just installed a Catweasel card in my Pegasos (Morphos 1.4). And it
    just doesn't work.
    First the symptoms:
    When I boot my Peggy I get the following messages:
    Please insert df0_hd
    Please insert df0_dd
    Please insert ph0
    Please insert pd0
    I installed the drivers trying 3 different installation instructions,
    one of them is:
    http://www.geocities.com/SiliconValley/Chip/6864/whota605/cw1.htm
    For the physical installation I plugged the Catweasel in a free PCI
    slot,
    disconnected the floppy cable from the motherboard
    and connected it to the Catweasel Card (red line on Pin1)
    I tried with both connectors and with two PCI slots.
    Do you see something I did wrong? I have no idea what
    the hell is happening, any help is welcome.
    Cheers
  • »25.11.03 - 17:16
