Will this video card work with MorphOS & my Power Mac?
    Dougal
    Posts: 77 from 2010/10/22
    Will this work ?
    "Apple Mac G4 ATi Radeon 9000 64MB AGP Graphics Card"
    I have a PowerMac G4 466Mhz which currently has an ATi Rage 16Mb. I believe my PowerMac is the Digital Audio version.
    Installed is Tiger and MorphOS 2.6
    Power Mac G4 1Ghz (Sonnet Encore) 640Mb, ATi Radeon 9000 Pro, USB 2.0
    OS: MorphOS 2.6 (Registered) , Mac OS X Tiger 10.4.11
  • »01.11.10 - 07:57
    Posts: 3274 from 2003/3/5
    That should work fine according to the DA specs.
  • »01.11.10 - 08:05
    .Quote:
    Dougal wrote:
    Will this work ?
    Yes, the Digital Audio Powermacs ought to be able to handle that card (and pretty much all other supported cards). Its not a bad system
  • »01.11.10 - 13:57
    Dougal
    Great because i bought one :)
  • »01.11.10 - 16:10
    That's the first card I had in my Quicksilver before I replaced it with a 9200. Since the MorphOS driver for the Rage128 doesn't support 3D, it should be a big improvement.
  • »01.11.10 - 16:26
    Simon
    Posts: 809 from 2008/7/6
    get ready for some eyecandy ;-)
  • »01.11.10 - 17:06
    Krashan
    Posts: 1107 from 2003/6/11
    I have the same card in my PowerMac "GigaBit Ethernet" 2 x 500 MHz. Works without any problems.
  • »01.11.10 - 19:05
    analogkid
    Posts: 713 from 2004/11/3
    I've also got this card in my PowerMac Gigabit, works without problems together with the original 400Mhz card and with an 1Ghz CPU card.
  • »02.11.10 - 05:12
    Dougal
    Great  :-)
    Can't wait for it to arrive... Where should i look for to see the differences from what i have now (Rage 16MB) to this one?
  • »02.11.10 - 06:20
