MorphOS Developer
Posts: 3311 from 2003/3/5
Well... that seems wrong indeed. Let's look at the third tab instead: it should generally look like
this. If it doesn't, change the peformed action to Keymapping. If that's already set and yet the key doesn't work, you'll have to add two actions looking like
this and
this.
Hope this helps :)
