PowerMac MDD 2x867 - boot problem
    madman
    Posts: 6 from 2010/10/15
    I have 2 almost identical PowerMacs G4 MDD - one is 2x867MHz (133MHz bus), other is 2x1.25GHz (166MHz bus). I'm exchanging gfx card (Radeon 9000 MAC edition) and hard disk between them.
    Problem is - the 1.25 one works OK, but 867 doesn't boot, I have to boot with alt pressed and click "next" (MorphOS is the only OS on this disk). When I do it - MorphOS works OK, when I don't - I have white screen, but I can reboot through ctrl-amiga-amiga.
    Where could be the problem?
  • »28.10.10 - 05:04
    Simon
    Posts: 809 from 2008/7/6
    are your jumpers on your drives set to master/slave instead of cable select ?
  • »28.10.10 - 05:08
    madman
    No, it was CS on HD. I've changed it to Master (it's single drive), no results.
  • »28.10.10 - 05:40
    amiades
    Posts: 231 from 2005/6/2
    Perhaps the default boot parameter in openfirmware is not good enough? It might have being modified for MacOS, and it tries to boot somewhere else... although the fact that crtl+amiga+amiga reboots probably invalidates this option...
    The part about that it boots while pressing alt and selecting morphos, makes me think about something with openfirmware boot parameters...
  • »28.10.10 - 11:28
    madman
    Someone told me to reset openfirmware (via reset-nvram and reset-all in OF), I've done it with no result.
  • »28.10.10 - 13:35
    Posts: 607 from 2003/4/11
    According to my info, the dual 867 is
    PowerMac3,6 (MPC7450): dual 867 MHz (internal L2 256KB, external L3 2MB)
    There is a known problem with MPC7450 CPUs if the console is active (which it is for Radeon9000)
    It will be fixed for next update.
  • »28.10.10 - 14:11
    madman
    Where did you get that info? According to my knowledge - all MDD have 7455, and MorphOS says the same.
  • »28.10.10 - 14:39
    Posts: 12537 from 2003/5/22
    > According to my info, the dual 867 is PowerMac3,6 (MPC7450)
    "Processor Type: PowerPC 7455 (G4) x2"
    http://www.everymac.com/systems/apple/powermac_g4/stats/powermac_g4_867_dp_mdd.html
    What's your source?
  • »28.10.10 - 15:17
    Ok, guess I need to update my info then.
  • »28.10.10 - 15:53
    Simon
    So what is madman's problem then ?
    What happens if you swap the cpumodules ?
  • »28.10.10 - 17:12
    madman
    I'll try tomorrow... I think it's not a problem, but maybe?
  • »28.10.10 - 17:23
    Simon
    Well depending on what happens you can rule out the cpuboard ( or not )
  • »28.10.10 - 17:34
    madman
    I've decided to leave CPUs as they are to avoid further problems. I assume that the connection Radeon-MDD867 is in some way bad, I'll test it with other card and maybe report.
  • »29.10.10 - 11:31
    Simon
    did you try to reset the motherboard with that little button next to the clock battery?
    I had some problems today with reinstalling MorhpOS, it always hanged during installation. I burned the ISO on three different CDRs, swapped hardrives and dvdrom ... nothing helped untill I pushed that button. I am not sure what was wrong and I also do not know what it did besides resetting Openfirmware... but it helped.
  • »30.10.10 - 11:48
