mount game disk
    bash64
    Posts: 974 from 2010/10/28
    Hello,
    I would like to mount a game disk in adf format that is known to have a normal filesystem but it won't come up. The game is battlechess and I remember it having an icon on the desktop that would install to your harddrive.
    I can understand getting errors with adfs that have no filesystem which a lot of games do not, but not one that does.
    Any info on playing old style games in morphos welcome.
  • »28.10.10 - 21:14
    Simon
    Posts: 809 from 2008/7/6
    Your really should play this with E-UAE .... even if you could get the adf mounted, it still needs the customchips that you do not have unless you have morphos on a classic equipped with ppc.
  • »29.10.10 - 03:35
    Posts: 3311 from 2003/3/5
    There are several ways to access ADF disks. You might find using http://de5.aminet.net/util/arc/Voodoo-X.readme easiest.
  • »29.10.10 - 05:04
    amyren
    Posts: 219 from 2010/5/15
    Nice. I wasnt aware that Voodo-X also managed adf's.
    And even better, I just tested - and it also can handle hardfiles as well.
    An other option for opening adfs is diskimage 37.7. This lets you map up to ten adf's simulaniously to the diskimage.device (unit 0 to 9). And then they can be mounted with the Mounter tool. Then each disk will pop up on the workbench/ambient screen just like they was real amiga floppy disks.
    Also there is a small command line tool named UnADF that lets you extract the files from an adf to a chosen destination. Subdirs will be maintained during extracting.
    Both these tools are found on aminet.
  • »29.10.10 - 18:52
    Korni
    Posts: 473 from 2006/2/23
    You can use fileimage.device or XAD. Both come with a standard MorphOS installation. For games it isn't very useful because most bang Amiga hardware directly. Use E-uae with adf or hd-installed games.
    [ Edited by Korni on 2010/10/30 0:12 ]
  • »29.10.10 - 19:09
