Overclocking Power Mac G4 MDD
    kickstart
    Posts: 227 from 2009/4/28
    Any advantage overclocking a g4 400mhz? or not worth.
  • »23.10.10 - 18:33
    baisaz
    Posts: 25 from 2009/12/17
    I didn't notice any difference between 400mhz and 450mhz. You can sometimes get lucky and push them up to 500mhz but no higher.
  • »23.10.10 - 20:53
    Posts: 12537 from 2003/5/22
    As usual: If you overclock by x percent CPU bound tasks will take only 100/(100+x) of the time.
  • »24.10.10 - 11:57
    insurgent
    Posts: 64 from 2007/7/8
    Could owners of MDD or FW800 with stock dual CPUs running at 1.42GHz let us know what temps the CPUs are running on startup and after say 10min?
    I have done service on the Power Mac that I purchased recently, including reapplying thermal paste. I used Arctic Silver. I'm getting temps stabilised at about 56 deg C. It seems a bit too high (given that 62 is the max) but then it will take a few hundred hours for the paste to cure. Should I be worryed?
    Also, this probably means no overclocking for me until CPU does the time :-)
    Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
    Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
    Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
    Dell UltraSharp 2407WFP 1920x1200
    PowerBook G4 ready :-)
  • »26.10.10 - 09:46
    pampers
    Posts: 1068 from 2009/2/26
    It's about 61,62 deg C. with proper heatsink and Verax cooling system.
    MorphOS 3.x
  • »26.10.10 - 10:21
