Hard Drive not regonised (Power Mac G4 3,4)
    sbeehre
    Posts: 3 from 2010/10/21
    Hi Everyone
    Im trying to install MorphOS 2.6 and when i go through the iWizard to install MorphOS on the hard disk it says i dont have a disk!? it boots fine into Mac OS X but MorphOS doesn't seem to see it... am I doing something wrong here?
  • »21.10.10 - 19:51
    Posts: 12498 from 2003/5/22
    May have to do with master/slave/cs jumpering.
  • »21.10.10 - 20:03
    sbeehre
    its on cable select and so is the CDRW drive
  • »21.10.10 - 20:06
    pampers
    Posts: 1061 from 2009/2/26
    So set it for master and try again.
    MorphOS 3.x
  • »21.10.10 - 20:16
    Divinity
    Posts: 498 from 2009/9/8
    @sbeehre
    yes, you need to set with the jumper the HD in master mode (if not, It's not seen in MorphOS)
  • »21.10.10 - 20:48
    sbeehre
    thanks very much for the fix!
  • »21.10.10 - 22:07
