M-Audio revolution 7.1
    pampers
    Posts: 1061 from 2009/2/26
    Hi
    I installed above card into my PowerMac today and installed Davy's drivers.
    I plugged in headphones and.. sound is a dissaster. It's so much overdriven, I cannot get any normal sound using sound prefs and mixer doesn't wont to see that card at all.
    Did anyone tried to get that card working propely?
    MorphOS 3.x
  • »15.10.10 - 18:21
    Posts: 591 from 2003/4/11
    You should probably contact Davy Wentzler directly about this issue.
  • »16.10.10 - 07:08
    pampers
    Frank, I just decided to ask in here, meaby some of MorphOS users have that card already. As far as I know Davy is visiting mzone from time to time :)
    MorphOS 3.x
  • »16.10.10 - 07:35
    Actually, I told him that the MorphOS release was immiment last week. Unfortunately, he didn't use that knowledge for some updated product promotion this week, though :)
  • »16.10.10 - 08:50
    pampers
    I've got the card working. It works only in HIFI mode. Sound quality is way better than built in sound card on my MDD.
    Unfortunatelly I cannot get DigiBooster Pro 2 working, for some reason it's really slow when trying to play module on Davy's drivers.
    Frank: is there any chance go get mixer working with external drivers?
    MorphOS 3.x
  • »16.10.10 - 10:07
    Not without Davy adding support for it. And as far as I understood, he is not really interested to support "special" MorphOS features as of now. The sales of his AE4 software - which was the actual reason to port the drivers - are below his initial expectations, basically.
    [ Editiert durch pega-1 an 2010/10/16 16:49 ]
  • »16.10.10 - 11:47
