MorphOS 2.6 & system monitor
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Hi
    Just updated MorphOS to 2.6 on my macmini . Thanks dev team :)
    THis might have alwayts been like this and only just noticed, but system monitor says my system is a powerMac10.2 ??
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »11.10.10 - 15:53
  • JJ
    JJ
    sorry to reply to my own topic and go OT
    But newb question. When you boot from cd you get eject icon and sound control on the menu bar. I notice in the release notes says you add stuff to bar. But how ?
  • »11.10.10 - 15:56
    Motosampy
    Posts: 199 from 2004/8/14
    Click and hold mouse button about 0.5 second on the right corner icon at the screen bar (or right click if you have double button mouse)
  • »11.10.10 - 16:04
  • JJ
    JJ
    Thanks dude. Not really had time top play around with MorphOS since I bought it
    [ Edited by JJ on 2010/10/11 20:42 ]
  • »11.10.10 - 16:40
    Posts: 12457 from 2003/5/22
    > powerMac10.2 ??
    That's completely correct. See http://www.google.com/search?q=%22powermac10%2C2%22
    And here on MorphZone:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6517&forum=3&post_id=66339#66339
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7413&forum=38&post_id=77274#77274
    And yes, it has always been like this :-)
  • »11.10.10 - 16:52
  • JJ
    JJ
    Thanks for the info , much appreciated. I thought it had probably always been like this. I have the same problems in work when we releease a new version of our claims system, we sudddenly got all sort of helpdesk saying this never used to happen before the cut, when its been the same for ten years.
  • »12.10.10 - 10:03
