MorphOS 2.6 on PowerMAC -> Weird keyboard (keymap) issue
    Everblue
    Posts: 170 from 2004/1/6
    Ok this is a weird one, maybe it is something I am doing wrong....
    I have a G4 PowerMAC (3.6) with its original keyboard, which is a UK Layout (the one with the pound sign on top of the 3).
    In MorphOS when I select UK Keyboard, I have the " and @ inverted (but the ? displays fine). It is like the keymap is broken a bit.
    Any ideas? Cheers
    Nostromo
    EDIT: I have checked my UK MAC Keyboard against a normal PC UK Keyboard and I can see that indeed on the MAC (even though its British) the " and @ are inverted. Hmmmmm....
    [ Edited by Nostromo on 2010/10/12 10:05 ]
  • »12.10.10 - 05:04
    Posts: 3311 from 2003/3/5
    Guess we should prepare some Apple kb layouts at one point... They indeed seem to have some keys placed in different locations than on PC kbs for the same language.
  • »12.10.10 - 07:20
    Everblue
    THanks for your reply :)
    I am a newbie to MorphOS - can I manually edit the keymap to replace @ with " ?
    Thanks
    Conrad
  • »12.10.10 - 07:37
