PCI Wireless network cards?
    Bifford
    Posts: 283 from 2003/2/24
    A nice simple question! :)
    What pci wireless network cards can be used on the Pegasos G4, and which is the best? (i'd probably look to Ebay for the sugestions).
    Cheers guys! :)
    Sam / Bifford
    Bifford the Youngest
  • »04.09.10 - 19:30
    Posts: 12537 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6042&forum=11#59566
  • »04.09.10 - 19:56
    Bifford
    Thank you Andreas!
    I did search for pci network cards but it didn't resolve anything and with that under the heading of Prism2 it's no wonder! :) Cheers!
    Sam / bifford
  • »05.09.10 - 06:21
    Bifford
    Next question which of the three would be better!? All three are on ebay (either uk or overseas) and how do you know the revision of the D-Link!?
    1. 3COM -> 3CRDW696
    2. D-Link -> DWL-520 (Hardware revision B2 or earlier)
    3. Netgear -> MA311
    Sam
  • »05.09.10 - 06:28
    Bifford
    Okay, I have bought a D-Link DWL-520+ which is revision B2 Ver 1.9.8.98
    I'm hoping the "+" at the end of the 520 doesn't make any difference..... but so far I've no success in making it work. But I shall continue the prism2 thread with that rather than on this thread!
    Sam
  • »27.09.10 - 15:03
