Posts: 715 from 2004/11/3
Although MorphOS would be the perfect OS for such a G3 machine nowadays, you're really out of luck. Not only this particular model won't be supported, the used ATI Rage 128 isn't supported by MorphOS, too. The best you can probably do is to use your B/W as a OS9 machine or install Linux on it. OSX should run upto 10.4.11, but it won't be fun.
