WD Elements 500GB USB External Drive
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    I have a USB ext HDD. Its formatted to NTFS and I wanted to use it for windows, mac, linux, and of course MorphOS.
    However in anything but windows shows as read only. Can MorphOS not write to NTFS drives or is this another issue?
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »24.08.10 - 17:32
    pampers
    Posts: 1068 from 2009/2/26
    Current NTFS drivers are not supporting writing under MorphOS. That won't change in a near future probably :(
    MorphOS 3.x
  • »24.08.10 - 18:16
    Posts: 3311 from 2003/3/5
    Our NTFS implementation is read only indeed and as far as I know, Marek said write support is too much work. If you want an FS that works everywhere, use FAT.
  • »24.08.10 - 18:21
    pampers
    Too much work? That has to be done when MorphOS will move over to x86. Just kidding ;)
    MorphOS 3.x
  • »24.08.10 - 19:20
    Divinity
    Posts: 512 from 2009/9/8
    Is ext2 filesystem writeable in MorphOS 2.5, right ?
  • »24.08.10 - 19:40
    Posts: 12537 from 2003/5/22
    Yes.
  • »24.08.10 - 20:28
  • JJ
    JJ
    Thanks
    Im guessing both MacOS and ubuntu will read and write FAT32.
    I suppose the only issue is the 4GB file sizes and using such a crap file system.
    What about MAC os filesystem, will MorphOS and Linux read and write this. I can loose windows if needs be so what would the best file system be for the other three, is it still FAT32 ?
  • »25.08.10 - 09:23
    Yomgui
    Posts: 348 from 2004/8/31
    @JJ: format it with SFS!
    What? SFS is not supported on Linux/Windows/Mac? Ask them to support it!
    :-D :-D :-D
    And now... next project!
  • »25.08.10 - 09:27
    boot_wb
    Posts: 874 from 2007/4/9
    HFS is r/w under MorphOS and Ubuntu, but has similar limitations as FAT32.
    HFS+ is read-only under MorphOS, can't remember if Ubuntu has r/w support for it.
    Fat32 is available to all r/w.
    HFS is available to all r/w.
    Ext2/3 is available to all r/w (fuse-ext2 under OSX).
    No idea about reliability of HFS & Ext2/3 handlers (under MorphOS/Ubuntu), but Fat32 is well tried&tested.
    [ Edited by boot_wb on 2010/8/25 13:35 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »25.08.10 - 09:33
    kolla
    Posts: 106 from 2003/4/22
    Linux had SFS support, but noone was willing to maintain the code, so it was removed.
    -- kolla
  • »31.08.10 - 16:00
    stephen_robinson
    Posts: 746 from 2007/4/22
    I couldn't get my mac to see a 260GB NTFS USB drive, did you need to do anything to get it work? So I gave up and put FAT32 on it...
  • »31.08.10 - 16:24
