Does MacMini burn DL DVDs?
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Hi Have the silent upgrade MacMini (in work at moment and cant check with system profiler) it has the dvd burner driver, superdrive or whatever its called. Do these support dual layer as in burning
    I want to check before buying pretty expensive DL discs on way home from work ?
    [ Edited by JJ on 2010/8/31 15:56 ]
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »31.08.10 - 11:55
    Posts: 3311 from 2003/3/5
    According to various sources, this may vary per unit. You should better check which drive you have exactly (and whether it actually works OK or not ;) before buying anything.
  • »31.08.10 - 12:24
  • JJ
    JJ
    Ok thanks for your reply
  • »31.08.10 - 12:47
