Samsung ML-2010 printer
    clansman
    Posts: 1 from 2010/3/1
    Can someone tell me is there any driver for this printer, I can't find it..can i use this printer if it is shared on PC?
    Thanks
  • »23.08.10 - 07:15
    boot_wb
    Posts: 874 from 2007/4/9
    From a brief reading of the documentation it appears that this printer uses a GDI-type printing language (SPL - Samsung Printer Language).
    For a list of all _officially_ supported printers, see here. Others are (as noted at the bottom of the list) supported via emulation.
    For this printer it appears that there is no official support for direct connection, although you could try a generic postscript output see if it accepts it. As a general rule, PCL printers are supported for direct connection - I have a Kyocera Mita FS-1010 (which emulates HP Laserjet PCL) which works fine.
    Alternatively, if the print server accepts LPR then you could use the netprinter utility (included on the MorphOS 2.5 disk contributions drawer) for network printing with the Printer connected to your PC (or if it has an inbuilt printserver, connected directly to your router).
    [ Edited by boot_wb on 2010/8/23 13:04 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »23.08.10 - 08:57
    Posts: 12537 from 2003/5/22
    I guess that PostScript compatibility would be listed in the ML-2010's specs if it was there.
  • »23.08.10 - 09:30
