Problem with USB storage devices (MorphOS 2.5 on Mac mini.)
    gleng
    Posts: 38 from 2006/10/15
    Hi All,
    I'm just wondering if anyone else is experiencing this. I've tried copying files from a couple of USB flash drives, a USB card reader, and a USB hard disc on my Mac mini running MorphOS 2.5 without success. I had the same problem under 2.4 but hoped the 2.5 update would fix it.
    The progress bar box pops up saying "buffering..." but hangs forever and copies nothing. If I try copying from the command line, I get the same problem.
    Is there any settings I can play around with to try and fix this?
    Thanks.
  • »14.07.10 - 08:46
    Posts: 3311 from 2003/3/5
    First start from checking Poseidon logs in System Preferences / USB. Sometimes there is a need to tweak some device specific settings in order for USB sticks to work right. Another reason might be low power or low quality cabling.
  • »14.07.10 - 09:30
    gleng
    OK, thanks! I'll have a play with the settings when I get home.
  • »14.07.10 - 09:56
    gleng
    Fixed!
    I changed from "trust device" to "override to bus powered" in the information window, and enabled "Better removable support" under the settings. All working great now. Thanks!
  • »14.07.10 - 17:03
