Overclocking Pegasos G3
  • -D-
    -D-
    Posts: 118 from 2003/5/2
    Well, has anybody tried to o/c their Peg to
    700mhz or more? :D
  • »09.11.03 - 08:27
    DJBase
    Posts: 745 from 2003/4/6
    Yes, but it seems you have to setup also some options in the OF. To set the jumper on the CPU card want give you the right effect.
  • »09.11.03 - 11:28
    DSLCC
    Posts: 246 from 2003/5/14
    My Peggy is sooooo fast the way it is. Have not considered messing
    with it. :)
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »09.11.03 - 18:04
    Posts: 157 from 2003/3/3
    Yep.. Only times I have felt the need for faster CPU was with Linux ... With MorphOS 600MHz G3 is more than enough.
    http://somequicknotes.blogspot.com/index.html
  • »10.11.03 - 15:45
    Posts: 278 from 2003/3/4
    I was feeling the same until I started to use mencoder. Now a dual G5 would make sense :-o
  • »10.11.03 - 16:31
  • Targhan
    Posts: 2833 from 2003/2/8
    Heh, I guess if you want to encode DiVX's that the faster the better.
    I'm trying to hold out for a G5 Peg2 :-D
    :idea:Targhan
  • »10.11.03 - 16:36
