USB Digital Voice Recorder with MorphOS
    osco
    Posts: 680 from 2009/10/20
    Any have one compatible?  8-)
  • »18.05.10 - 15:29
    kriz
    Posts: 314 from 2005/10/18
    yes i also need this. I got a snowball USB mic, but no software...Maybe Hd-Rec is up to it ?
  • »18.05.10 - 16:20
    Tomo
    Posts: 93 from 2003/7/29
    A simple solution is to use ahi-recorder and plug in a mic with small pin in the back of the pegasos (or use an adaptor-pin) .You can save as WAV or AIFF. Use a converter for the producing of an MP3-file.
    Regards Tom
  • »18.05.10 - 18:42
    pampers
    Posts: 1068 from 2009/2/26
    I'd say we are talking about Mac Mini in here :)
    MorphOS 3.x
  • »18.05.10 - 18:48
    Posts: 2090 from 2003/6/4
    No. usb audio devices are using the usb isochronous transfer protocol* which unfortunately is not (yet) supported by Poseidon.
    *) it is a mode that warrants transfers of a certain ammont of bytes at a time, but does not warrant successful transfer. A failed transfer will get dumped. it is intended for sreaming applications like audio or video.
    [ Edited by Zylesea on 2010/5/19 0:02 ]
  • »18.05.10 - 19:01
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Actually, Poseidon supports isochronous transfers, depending on drivers. pciusb.device (used on Pegasos/Mac/... ) doesn't support it, but the deneb driver does.
  • »19.05.10 - 00:09
