MacMini Open Firmware Boot To Morphos Glitch
    Jason
    Posts: 14 from 2009/11/6
    Hardware: MacMini 1.5 GHZ 64MB VRAM
    I am trying to boot straight to MorphOS using a MacMini.
    I have set up openfirmware using the following command:
    setenv boot-command boot hd:2,\\bootinfo.txt
    Although it works, MorphOS only sees 32mb of vram with this method.
    Is there a flag or switch I must set in Open Firmware to ensure MorphOS sees the full 64MB of vram?
    MorphOS sees all 64MB vram when booting using the mac boot selector (hold alt during boot)
  • »22.04.10 - 12:14
    Piru
    Posts: 617 from 2003/2/24
    MorphOS 2.4 in Mac Mini has a bug where it only sees 32MB of the 64MB under certain conditions. Next MorphOS release will fix this.
    [ Edited by Piru on 2010/4/22 18:28 ]
  • »22.04.10 - 12:27
    Jason
    Thanks for the fast reply.
    Is there a 'known issues' list or web page that I can look at so I don't fill out needless bug reports?
  • »22.04.10 - 12:32
    pampers
    Posts: 1068 from 2009/2/26
    As far as I know there isn't but you can always use search button in here, because there is a few good threads about bugs in current version of MorphOS.
    Welcome at MZone :)
    MorphOS 3.x
  • »22.04.10 - 14:16
    Posts: 12536 from 2003/5/22
    > full 64MB of vram? MorphOS sees all 64MB vram when booting using the mac boot
    Old thread about that:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6560&forum=11#67736
  • »22.04.10 - 16:15
    uGod
    Posts: 12 from 2005/10/20
    Hi Jason!
    If you want OSX aswell, you can try installing OSX
    first, leaving enough space for MOS, then install MOS.
    It works for me. MOS boots as default, and it sees the full 64MB of VRAM.
    Bye -uGod-
  • »23.04.10 - 08:39
    > you can try installing OSX first, leaving enough space for MOS, then install MOS.
    That won't help his problem.
  • »23.04.10 - 17:39
