MacMini 2048x1152 Glitch
    Jason
    Posts: 14 from 2009/11/6
    Hardware:
    MacMini 1.5GHZ
    1GB Ram
    54MB VRAM
    Description:
    There is a graphics error when in the 2048x1152 resolution.
    Windows which are close to the right edge of the screen lose their drop shadow. Windows stretched the full width of the screen get graphics corruption.
    All 3d blankers fail or crash the system at this resolution.
    Changing the colour depth does not remove or reduce the glitches. Changing the display enhancement modes does not remove or reduce the glitches. The glitches appears to be a driver problem rather than lacking VRAM.
    I have already run Apple Hardware Test for MacMini and it reports no VRAM or other problems.
  • »22.04.10 - 11:53
    Posts: 12408 from 2003/5/22
    > 54MB VRAM
    Sure? ;-)
  • »22.04.10 - 16:11
    Posts: 236 from 2003/7/28
    I reported this bug ages ago - btw it's not the Mac Mini. It's the 2048 pixel width.
    Hopefully MorphOS team will find a fix/work-around...
  • »22.04.10 - 19:05
