Pegasos 2 died ?
    Motosampy
    Posts: 199 from 2004/8/14
    Since last night my Peg2 G3 refuses to boot after making one minor adjustment to nvramrc. Now at power on hd starts, hd led goes off and then flashes shortly, but keyboard leds do not flash and no signal to screen... Tried removing the battery, changing memory module and disconnected everything extras...
    So I think something has gone wrong in writing nvramrc. Is there some other way to restore factory state than sending the motherboard for repair ? (If no, this will sadly end my MorphOS usage...)
  • »06.04.10 - 14:49
    Posts: 1385 from 2010/1/6
    If you can't keep him running again: Write a mail to tk@bplan-gmbh.de (= Thomas Knaebl from BPlan, the producer-company of Pegasos). Normaly they can repair any Peg (there are enough spare parts....) or can reflash the OF..... (They repared my PEG2 during 4 weeks...).
    [ Editiert durch Amigaharry2 an 2010/4/6 21:03 ]
  • »06.04.10 - 16:02
    Posts: 607 from 2003/4/11
    You forgot to mention that taking the risk to kill the flash usally isn't for free, though :)
  • »06.04.10 - 16:24
    magnetic
    Posts: 2129 from 2003/3/1
    Motosampy
    Sorry to hear of your problems with your peg. if you search the internet there is way to reflash it yourself iirc..
  • »06.04.10 - 20:55
    zukow
    Posts: 655 from 2005/2/9
    @Motosampy
    what does OF serial debug say ?
  • »07.04.10 - 06:58
    Motosampy
    Coudn't find my nullmodem cable, I'l try to buy a new one for the weekend and try to see
  • »07.04.10 - 15:46
    Motosampy
    How do I grab the serial debug output so that it's readable to someone ?
    Got in contct with Thomas Kn?bel, there's some life, wishing for the best :)
    And back in the game !
    Allthough G3 is a slow processor I'm still happy to be able to use my Peg ! One day I'll have enough savings to register MorphOS too
    [ Edited by Motosampy on 2010/4/9 23:10 ]
  • »09.04.10 - 14:50
    This might be helpfull for you:
    http://www.freescale.com/files/32bit/doc/app_note/AN2748.pdf
    read chapter 6 for serial port......
  • »10.04.10 - 18:08
    Posts: 2090 from 2003/6/4
    You need a computer with serial port and a terminal software. I use an old Amiga for that purpose and the software "Term" which is btainable from http://www.chebucto.ns.ca/Services/PDA/AmigaComm.shtml . On Windows maschines there are plenty free terminal progams, too (Windows itself has one build in). Just select the serial port as input and chose receive data. Then everything that the Peg sends out should get written to the terminal software. It is rather easy and straight forward.
  • »10.04.10 - 20:08
