USB sd card reader
    osco
    Posts: 680 from 2009/10/20
    How do you show it in Ambient?
    Posieden sees it as a scsi device unit 0
    It shows it is manual mounted?
  • »09.03.10 - 16:57
    pampers
    Posts: 1061 from 2009/2/26
    I have no problem at all with my card reader on USB. Poseidon recognize any card i plug in straight away.
    MorphOS 3.x
  • »09.03.10 - 18:44
    CountRaven
    Posts: 566 from 2007/12/10
    Same here on Peg2, never tried on MacMini.
    You can try Mounter to mount the device on desktop. It is stored on the Tools directory I think or somewhere near there. :))) Be sure to have a card on the card reader, the device itself means nothing to MorphOS. The card will be your actual drive, not the card reader.
  • »10.03.10 - 05:14
    beworld
    Posts: 668 from 2010/2/10
    no problem with my usb card reader on MacMini :)
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »10.03.10 - 09:46
