Poseidon 4.4
    Divinity
    Posts: 512 from 2009/9/8
    Is It possibile to update Poseidon 4.2 in MorphOS 2.4 to Poseidon 4.4 ?.
    http://www.platon42.de/files/usb/PoseidonV4.lha
  • »15.02.10 - 23:08
    Posts: 607 from 2003/4/11
    No, this is an 68k only update intended for 68k legacy AmigaOS.
  • »16.02.10 - 01:31
    magnetic
    Posts: 2129 from 2003/3/1
    Divinity
    AFAIK there will be a Poseidon update (as usual) in the next ver of Morphos!
  • »16.02.10 - 22:07
    MaveRickPL
    Posts: 73 from 2009/12/30
    New version will faster (coping a data from pendrive/data drive)? Copy speed is a problem in Poseidon or hardware ?  :-?
    [ Edited by MaveRickPL on 2010/2/16 20:10 ]
    MacMini & MorphOS
  • »17.02.10 - 00:00
    xyphoid
    Posts: 870 from 2008/7/11
    on what system? it's slow on efika with the usb1.1 not sure about peg1, not much of a problem on macmini with usb storage device transfer.
  • »17.02.10 - 02:33
    Posts: 236 from 2003/7/28
    Poseidon 4.4 is nice, running it with my Deneb now :) 8-)  8-)
  • »17.02.10 - 02:34
    MaveRickPL
    I have MiniMac and transfer from USB pendrive is slow... like USB 1.1
    MacMini & MorphOS
  • »18.02.10 - 02:10
    Posts: 1521 from 2003/2/24
    @MaveRickPL
    How many MB/s you get with Mac mini?
  • »18.02.10 - 06:03
    Crumb
    Posts: 736 from 2003/2/24
    @MaveRickPL
    I get >15MB/s transfering files through Mac Mini usb. Are you sure your pendrive can work at fastest speed? If you use an usb hub keep in mind that some of them degrade speed if you don't use external psu.
  • »18.02.10 - 07:20
    Posts: 2090 from 2003/6/4
    Maybe your stick is slow? I have sticks that just reach less than 2MB/s, but other usb storage mediums that reach about 15MB/s (on Mac mini that is).
  • »18.02.10 - 08:48
    MaveRickPL
    If I plug in pendrive in apple keyboard i have 900kb/s. When I plug in on back of MacMini i have 15MB/s. But is much more easier plug in to keyboard...
    Iam using Kingstone Traveler 100 SB Pendrive to move stuff... its not slow.
    [ Edited by MaveRickPL on 2010/2/18 14:31 ]
    MacMini & MorphOS
  • »18.02.10 - 18:16
    pampers
    Posts: 1068 from 2009/2/26
    As Zylesea said - keep in mind that some sticks are slow. My bloody and cheap kingston is a disgrace but with my external USB HDD i'm getting about 15-16MB/s under my Mini.
    MorphOS 3.x
  • »18.02.10 - 18:28
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @MaveRickPL
    That's quite expected, since you likely have a USB1.1 Hub in your keyboard.
  • »18.02.10 - 21:15
