MorphOS on PPC Servers?
    Dreamcast270mhz
    Posts: 152 from 2009/12/8
    Have any of the dev team ever thought of making a server edition of MorphOS? The PPC Xserve, for example, is still in much use around the world. If you packaged MOS with server drivers and much of the required server software this could do many things:
    You could make more money because you would increase the user base.
    The price currently is inexpensive compared to other server OSes
    It would allow you to stick with PPC hardware longer, there are many models to cover.
    It would attract more developers
    You would also save potential customers lots of money, because they wouldn't need to upgrade their server.
    My Macs:
  • »16.01.10 - 16:57
    Posts: 1521 from 2003/2/24
    MorphOS is not a server OS: it lacks both security and reliability (memory protection).
  • »16.01.10 - 18:23
    Dreamcast270mhz
    Okay, as for security, why did Winserver 2003 sell so well? It has MASSIVE security holes. As for memory protection, I know it would be hard to implement and maintain amiga compatibility, not to mention other things.
    Anyways, itix, it was a thought for the future, not to be taken to make a quick, dirty port to the Xserve G4.(or any other Server for that matter) And neither would I need a server edition. Your part of the devs, so you may take this as you wish. I just happened to have this thought, and of course it would need several improvements, but consider these pros for MOS as a server OS:
    Lightweight, low footprint= better server performance
    Multitasking= More capable of filemanagement, traffic handling and whatever else it may need to do.
    Also, consider the following things that a server version of MOS may not need:
    Trance
    GUI (some servers may not require one, others may)
    Of course, I'm still VERY new to MOS, not even owning a capable system atm, so I may have omitted or be missing some points. Anyways, as a fan, I respect your opinion and your dedication/hardwork. If you do a port to Xserve G4, with server specific stuff, i'd buy one and a license, even if it was higher priced than the workstation version
    My Macs:
  • »16.01.10 - 19:42
    kolla
    Posts: 106 from 2003/4/22
    The only way I would want to run MorphOS on a server is on a virtual machine hosted on one. The idea of using MorphOS as a server OS is just insane, sorry. MorphOS lacks all features needed and brings *nothing*.
    -- kolla
  • »17.01.10 - 02:45
    Matt_H
    Posts: 30 from 2009/2/21
    Agreed, a port to the XServe to use as a server doesn't make much sense. A port to the XServe to use in a 1U studio environment, however, might fill a niche.
    But with all the hardware out there that could potentially run MorphOS, the XServe should probably be the lowest priority.
    [ Edited by Matt_H on 2010/1/17 10:27 ]
  • »17.01.10 - 13:26
