Efika MorphOS install timeout issues
    Tronman
    Posts: 209 from 2003/3/3
    First, the good news-I got my Efika working, yaay!!
    I found a USB stick that it seems to like (reads it from OF) and put the MOS 2.4 install image on it from morphosteam.net.
    Last night, I followed the instructions and it booted right up into MOS! So I followed the installer instructions, trying to get the install iso from the site URL provided in the installer's default path, even setting it to not download to RAM:. I only got about 25 Kbytes/sec transfer, and that would have been fine-except that MorphOS times out-and slows waaaay down-before the image can even get downloaded! I got to 73 percent by leaving it overnight, but then of course the server timed out or something because it stopped loading.
    Is there a way I can get the actual MOS 2.4 ISO, put it on the USB stick and go that route instead? The stick is 2GB, so lots of room there.
    The other error I encountered today is that I'd type boot scsi0: morphos-2.4-efikainstall.img at the OF prompt, then get a series of capital R s printed out, then 'error: network timeout' which didn't happen last night. Nothing changed in terms of my LAN, which worked last night.
    Not sure what to do about the network timeout thing. Any suggestions?
  • »12.01.10 - 19:07
    Posts: 1354 from 2004/2/8
    You can download the .iso from here. Just do it on any other computer.
    About the "RRR problem" - never seen something like this. Have you tried copying efikainstall.img to the stick once again? Or unplugging the Ethernet cable?
  • »12.01.10 - 20:22
    Posts: 140 from 2003/9/16
    The fastest method is always to have the installer boot image and the very iso image in the usb drive.
    About the key printing issue, try downloading another installer and/or reformatting the usb drive. Seems the elf is somewhat corrupted.
    BTW, If you can try and external usb hdd instead of a usb thumbdrive. maybe its rewarding, as the hdds seems to be more efika friendly.
    [ Edited by FrankBrana on 2010/1/12 23:47 ]
  • »12.01.10 - 22:45
    Tronman
    Wow, thanks guys!
    Downloading the OS iso right now. I did try unplugging the network cable, but still had the other error. Also trying reformatting the USB stick. It's a 2GB Sandisk, but when you insert it into a computer it always seems to have three partitions on it which no Mac or PC seems to want to remove. So, when I get MOS going I can reformat the stick using MOS' disk tools and have it all one volume to make things easier. I hope..
  • »12.01.10 - 23:54
