What happens if you try to install MorphOS on a non-mini Mac
    As mentioned in the subject, I curious about what happens if you try to install MorphOS on a G4 Mac (other than the Mac Mini).
    Some of the G4s have hardware that's very similar to the Mini.
    Sorry if this question has been posted before.
  • »03.01.10 - 20:10
    pampers
    Posts: 1068 from 2009/2/26
    Question is simple: nothing..
    MorphOS 3.x
  • »03.01.10 - 20:17
    Posts: 2090 from 2003/6/4
    MorphOS kernel checks for a hardware identifier, if it doens't match, it refuses to boot. Wait for the next release with PowerMac G4 and eMac (was that one officially confirmed?) support.
  • »03.01.10 - 20:26
    OK, the first answer was (obvious) the truth, but thanks for the second reply. That helped me understand why it wouldn't work.
  • »03.01.10 - 20:34
    Posts: 12536 from 2003/5/22
    http://www.osnews.com/story/22337/The_Amazing_MorphOS_2_4_G4_Mac_Testing_Effort_
    Guess what came out of it ;-)
  • »03.01.10 - 20:44
    Nice! I can't believe you came up with that this quick.
  • »03.01.10 - 22:47
    I knew that article, so I just had to remember it ;-)
  • »03.01.10 - 22:56
    Sometimes you scare me Andreas.
    Well, I can play around now until an official release.
    Unfortunately I only have a Radeon 9000Pro on hand (64MB), but it should do.
    Thanks!
    [ Edited by Jim on 2010/1/4 1:27 ]
  • »03.01.10 - 23:25
    By "guess what came out of it" I meant to say that nothing came out of it. You can try of course, but that's wasted time in my opinion.
    > Unfortunately I only have a Radeon 9000Pro on hand (64 MB)
    Radeon 9000 Pro is perfectly fine in terms of MorphOS support.
  • »03.01.10 - 23:55
    Its OK, I can wait. It gives me time to locate a faster G4 processor.
    Take care.
  • »04.01.10 - 00:21
