Competition pro usb joystick reacts to slow in uae
    amiga4001
    Posts: 454 from 2006/11/16
    I am using a competition pro usb joystick on a windows machine with uae.
    I am running turrican in the emulation with help off whdload.
    All directions are going ok but not for sideways jump and in the jump go back to the right.
    It doesn't react fast enough on the changes off the positions off the joystick it seems.
    I also looked into the gamecontrolsettings in the windows config.
    Here it also doesn't react to a movement to the left.
    Are these joysticks this bad?It is barely used.
    May have to try it on the pegasos and uae to see what it does there.
    Uae is running speedwise quite nice on the windows machine btw.
    Maybe I'll invest in an adapter to hook up one off my old favorite suze the arcade to usb better joysticks much better.
  • »29.12.09 - 18:15
    hooligan
    Posts: 1948 from 2003/2/23
    Plain and simple: the product is piece of shit junk. In any way imaginable.
  • »29.12.09 - 18:23
    Captainthunder
    Posts: 14 from 2003/10/29
    Did you find such a adapter yet?
  • »30.12.09 - 08:25
    amiga4001
    I found a product a few days ago on the net.
    Can't recall the link or name...I'll find it again.
    There is offcourse also the way off hacking a cheap usb joystick and wire it's buttons to a DB9 connector.but I prefer a ready to go product.
  • »30.12.09 - 17:42
