Posts: 1354 from 2004/2/8
Hi
One of the Polish MorphOS users has a serious problem with his Pegasos II G3/600 MHz (OF 1.2). Here are the symptoms:
- it started when his Pegasos refused to work after reset (black screen, no monitor/disk activity, no OF prompt, keyboard doesn't work).
- further resets and unplugging the ethernet cable did nothing.
- unplugging drives, removing and re-inserting memory didn't help too.
- changed the battery, PSU, and swapped some other memory chips with no effect.
- graphic card seems to be OK (tested with success on a PC).
here are some serial logs:
memory present:Quote:
PegasosII Boot Strap (c) 2002-2004 bplan GmbH
Running on CPU PVR:00083311
Enable L1 ICache... Done.
Reading W83194 : 00FFFFFFFFFF0000 Done.
Setting Front Side Bus to 133MHz... Done.
Memory has not changed
Configuring Memory
Memory Config Done
Configuring PCI0... Done.
Configuring PCI1... Done.
Configuring ETH... Done.
Releasing IDE reset ... Done.
Configuring Legacy Devices
Initializing KBD...00000032 FAILED. (when keyboard present, it goes "Done")
Testing 10000000 Bytes, Pass: 00000000 Failed: 00000000
RAM TEST (fill random)... Done.
SmartFirmware:
cpu0: PowerPC,750CXE CPUClock 599 Mhz BUSClock 133 Mhz (Version 0x0008,0x3311)
no memory present:
Memory changed since last boot
Configuring Memory
Memory Config FAILED
Testing 00000000 Bytes, Pass: 00000000 Failed: 00000000
Entering IKARUS low level console
memory re-insertedQuote:
Configuring Memory
QZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZFQZF
Memory Config Done
SmartFirmware:
Anyone knows what could be wrong? Could it be the CPU card (visually it seems OK)?.
