External speakers for the macmini?
    osco
    Posts: 680 from 2009/10/20
    Header says it all.
    TIA :-D  :-D  :-D
  • »01.12.09 - 01:42
    stephen_robinson
    Posts: 746 from 2007/4/22
    Yes. They work.
    It's a stereo output jack, I don't understand the question. I've got mine into a Quad 34/303 into some Sony, possibly speakers. Other amplification/speaker systems are available.
  • »01.12.09 - 05:16
    osco
    Apple had "Apple Pro Speakers" that used a Apple specific mini jack that was smaller than the MINI'S. So generic speakers will work for the Mac Mini? :-(
  • »01.12.09 - 11:53
    osco
  • »01.12.09 - 11:53
    Posts: 2070 from 2003/6/4
    Th emini uses a 3.5 mm jack. The early ipods used special jacks IIRC.
  • »01.12.09 - 12:02
