Posts: 2077 from 2003/6/4
If you have drives of the same priority you can force MorphOS to boot from a certain drive by giving the boot parameter "bd dhx" where dhx denotes the actual partitition you would like to boot off.
Lets assume your MorphOS 2.2 installation is on dh0 you need to type (given the V2.2 boot.img resides at ide 0,0:0 in terms of the smartfirmware.
boot pci/ide/disk@0,0:0 boot.img bd dh1 rds rd 2
Currently I don't have my Efika (or my Peg) around here, thus I am not sure whether this pci/ide/disk@0,0:1 is correct or not (it is just IIRC). The rd rds 2 part just tells to use ramdebug with a littel buffer.
[ Edited by Zylesea on 2009/11/30 12:00 ]
