Strange behaviour....
    Robert
    Posts: 331 from 2003/5/12
    Something weird is happening.
    After installing an additional HD, partitioning & rebooting, the Peg
    now takes much longer to boot and Installer no longer works.
    I'm pretty sure I haven't changed anything else.
    Any clues what happened?
    Thanks,
    Robert.
    Robert.
  • »23.10.03 - 22:30
    poundsmack
    Posts: 1346 from 2003/6/8
    do u have morphos installed on both hard drives? the boot process may be trying to load from 2 sources. that happend to me with linux
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »23.10.03 - 22:38
    Robert
    @poundsmack:
    No. Apart from being partitioned it's empty.
    Robert.
  • »23.10.03 - 22:50
    Posts: 1520 from 2003/2/24
    Have you tried another IDE channel?
  • »23.10.03 - 23:01
    Robert
    I haven't, no.
    It's not something I would have thought of - why would that make a
    difference to Installer working?
    Robert.
  • »23.10.03 - 23:12
    I wonder that too. But you never know...
    Is your 2nd drive old btw?
  • »23.10.03 - 23:37
    poundsmack
    did u make sure they are not both designated as master? ;-)
  • »23.10.03 - 23:49
    Robert
    About 3 months.
    First drive is a couple of years old.
    Robert.
  • »24.10.03 - 12:21
    Robert
    Fairly sure. I had to change the jumper settings several times before I could see it with scsi config.
    It still boots and I have one partition showing up - the FFS one.
    Robert.
  • »24.10.03 - 12:24
    poundsmack
    hmmmmg got me then sorry robert
  • »24.10.03 - 22:21
