Extra Mouse buttons
    weiseb
    Posts: 212 from 2003/3/29
    Is it possible to assign commands to Mousebuttons (PS2) like MMKeyboard does for keys?
  • »24.11.08 - 18:13
    Posts: 3279 from 2003/3/5
    The PS/2 driver only supports 3 mouse buttons, so I guess it doesn't make much sense. You can use the mmb for some hotkeys in IControl though.
  • »24.11.08 - 18:42
    Posts: 1076 from 2004/9/23
    You can use the tool Meridian.
    Meridian allows to assign commands to mouse gestures. So you can setup even more actions by using just a single mouse button or key qualifier.
    http://www.geit.de
    Geit
    [ Edited by geit on 2008/11/24 23:33 ]
  • »24.11.08 - 20:30
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    Well, on my A4Tech Mouse the 4th mouse button is recognized, but as a second middle mouse button. So maybe it would be a solution to connect the mouse to the 9 pin serial connector using an adapter, install the AmigaOS driver and configure it to use serial.device unit 0. Problem is, that the driver was delivered on an FFS formatted floppy disc, that cannot be read by lame Pegasos Floppy Controller...so if someone has a download link...?
  • »24.11.08 - 20:58
    Qwert44
    Posts: 22 from 2009/11/16
    Is there any very basic method to assign LAMIGA+M (next screen) to middle mouse button?
  • »22.11.09 - 10:09
    Jambalah
    Posts: 820 from 2008/3/30
    @Qwert44:
    Yes. Go to the global prefs and click on IControl. Modify the "lcommand+m" (used for next screen jump) pressing the right selector and choosing "sample". Then click on the middle mouse button and wait for prefs to store it. Done!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »22.11.09 - 11:54
    Qwert44
    Superb, thanks a lot!
  • »22.11.09 - 16:26
