Ati radeon 9200 mac mini 1.5 64megs
    osco
    Posts: 680 from 2009/10/20
    Supported Display Graphics: VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), UXGA (1600x1200), QXGA (2048x1536), 1152x864, 1920x1200, 1920x1440, 1920x1080
    Apple widescreen display 20" 1680x1050 99.06 aluminium A1081 DVI-D Apple Cinema Display 65W 14 ms
    will the graphics card support this monitor?
    tia 8-)
  • »19.11.09 - 02:07
    Posts: 236 from 2003/7/28
    @osco
    It should. My Mac Mini supports 2048x1152. Same model as yours. 1.5Ghz with 64MB Vram :-)
  • »19.11.09 - 02:14
    Posts: 2077 from 2003/6/4
    1600x1050 is definitely no problem. I use this resolution currently on my Mac mini connected by DVI to (some rater sucking) LG 22" monitor).
  • »19.11.09 - 06:47
    I am running a 1920x1080 16bit Ambient screen on my 1.5GHz 64mbVRAM MacMini with no problems on an Acer 23" widescreen LCD, so that monitor with a lower resolution screen should be no problem.
  • »20.11.09 - 03:45
  • rms
    rms
    Posts: 606 from 2004/11/27
    Strange, I have a Sun 24" Monitor which has a native and recommended resolution of 1920x1200@60 and I'm not able to select this one with my MacMini 1.5 Ghz 64mb Vram at 24bit and DVI. It let's me go up to 1920x1163@56 and this either at 16bit or 24 bit. IMO there must be something wrong with the driver in regard to the 9200, because I can display a resolution of 1600x1200@60 (native resolution of an Eizo CG 21) DIV connection when using a Radeon 9000, 128 mbvram and 128 bit, bit this is not possible when using the Radeon 9200Pro, 256 mbvram 128 but.
  • »20.11.09 - 04:37
