Mac mini: wich one to buy.
    Simon
    Posts: 809 from 2008/7/6
    I am not really interested in the cpu power... but is 32Mb videoram going to be a problem ?
    Should I really buy the 1.5Ghz with 64Mb Vram ?
  • »21.10.09 - 19:03
    Ruud
    Posts: 335 from 2009/2/2
    It all depends on usage. I use a monitor which is full 1080p and multiple screens so of course this requires more vram so I have the 64mb version. If you're not worried about cpu power and you think 32mb will be enough for your usage then the 1.25ghz version is the best buy. And I'm not just saying that because I've got three to sell ;-)
    Otherwise the 1.5ghz with 64mb vram is the only choice. Often 1.42ghz models seem to fetch almost as much whilst offering a lot less imho.
  • »21.10.09 - 19:11
    Posts: 2547 from 2003/2/24
    Well I'd say that depends on both your budget and the actual difference in price.
    Remember:
    Saving a few Euro now might be something to regret for years to come.
    Getting the 1.5GHz Mini means you get one of the latest, lesser used and fully debugged units (dunno wethere there were any major changes to the mobo, but the latest is the latest ).
  • »21.10.09 - 19:14
    Henes
    Posts: 507 from 2003/6/14
    Just a notice:
    Using multiple screens is not a real problem. If you run out of video memory then cycling screens will be slower because bitmaps will need to be swapped in and out. But this will not prevent you from opening more screens. And having other screens in the background will not slowdown operations on the frontmost screen.
    i.e. Quake3 will run at the same speed no matter how many screens you keep behind its own.
  • »21.10.09 - 19:44
    Ruud
    Slower? That is not something I can tolerate, I must have speed at all times :-p
  • »21.10.09 - 20:23
    kriz
    Posts: 310 from 2005/10/18
    I bought mine, 1,5 with 64mb from local norwegian used oage www.qxl.no .. I suppose it can get much more expensive on ebay now.. but keep loking for buy now auctions..
  • »21.10.09 - 22:34
    Henes
    Then you need as much video memory as normal memory. i.e. 512MB or 1GB :)
    [ Edited by Henes on 2009/10/22 11:57 ]
  • »22.10.09 - 07:56
    osco
    Posts: 680 from 2009/10/20
    Today is my birthday and my present is soon to be here!
    A Mac Mini @ with 64 megs of video ram. A 1.5 with the memory maxed and a new bigger hard drive. It will arrive in two days. First post with many to follow.
  • »22.10.09 - 09:59
    Spihunter
    Posts: 84 from 2003/7/9
    I just got a 1.25ghz mini w/ 512mb ram and 32mb video. Morphos really flies on this thing!. I running a pretty standard screenmode and doing basic sufing and music apps though.
    I could imaging that if you were doing video/graphic intensive stuff you would want the 64mb of video ram.
    17" Powerbook. MorphOS registered
    Hear my music here: Gordon Gallant
    And here: Kattalax
  • »22.10.09 - 10:08
    Posts: 1932 from 2003/10/19
    I have both a 32 and a 64 now and I cant see much of a diff on them. I would get a 1.25 if the price is good and you cant find a 64. It is way better then an efika in any case no matter which you get.
  • »22.10.09 - 13:05
    Posts: 2079 from 2003/6/4
    Happy birthday and welcome. You won't regret it. I run MorphOS n a Mini 1.5GHz since last week and it is georgeous!
  • »22.10.09 - 14:22
    Get27
    Posts: 90 from 2004/8/23
    Hello,
    french page about differents MAC mini models :
    http://amigaga.chez-alice.fr/ng/mac/mini_g4.htm
    1.33GHz models have 64Mb ram, normally
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »22.10.09 - 15:07
    Posts: 12521 from 2003/5/22
    I don't think so.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6112&forum=11&start=40#60712
  • »22.10.09 - 18:43
    Get27
    Ok Andreas_Wolf
    it's not very clear for this model beacause some of them have 64MB
    1.33GHz and Radeon 64MB on Ebay
    I have seen a other like this on other website but a i don't kept the link.
    [ Edited by Get27 on 2009/10/23 18:07 ]
  • »23.10.09 - 14:04
    Qwert44
    Posts: 22 from 2009/11/16
    Hi all,
    what performance boost you see from a 512Mb -> 1 GB Mac mini RAM extension?
    I plan to buy a Mini (1.5Ghz/64 MB VRAM) with 512 MB RAM and just wondering on expanding its RAM just after having bought it.
    thanks,
    Cheers
    [ Edited by Qwert44 on 2009/11/16 19:32 ]
    [ Edited by Qwert44 on 2009/11/16 19:33 ]
  • »16.11.09 - 17:31
    stephen_robinson
    Posts: 746 from 2007/4/22
    none in terms of speed, but it will allow you to run more programs, in principal, I never ran out memory with 512MB, so I didn't need to update my mac Minis, but I had the memory chip spare so I did. it's quite easy fitting it. Opening and shutting the case is the tricky bit.
    MacOS tiger/Leopard needs more than 512mb IMHO.
    Also, I find the fan makes more noise and spins up faster on heavy load on the 1.5Ghz, which it didn't on the 1.42 model. On both MorphOS and MacOS.
  • »16.11.09 - 17:42
    Qwert44
    Thanks -- I will use the tiny box primarly for MorphOs ... MacOS will run on other boxes. :)
  • »16.11.09 - 19:48
    Get27 wrote:
    Ok Andreas_Wolf
    I don't read French, but it appears that the speed of the G4 for that MacMini is listed as 1.49GHz in one place and 1.33GHz in another. The sellers in eBay auctions have often put the wrong numbers for CPU speeds and for the amount of RAM and VRAM installed, so I would not let one or two auctions convince you that any of the 1.33GHz models have 64mb VRAM installed, until you actually have one in your hands, or see a reliable screen shot which shows a 1.33GHz model to have the 64mb of VRAM installed in it.
  • »17.11.09 - 02:41
    Get27
    Hi amigadave,
    the 1.49 you seen is for search: "1.00 ? 1.49GHz" meens speed between 1.00 and 1.49GHz.
    I agree some users don't know what they have but not all (if graphic ram is specified, i think the vendor knows what he sells).
  • »17.11.09 - 13:50
    Qwert44
    Guys, this is amazing. Just installed MorphOS on a 1.5 Ghz mini. After several years of journey this is feeling like: you just arrived home. :)
  • »17.11.09 - 16:57
