Pegasos2 - Peg2 Cpu fan - Replacement ?
    kriz
    Posts: 314 from 2005/10/18
    My cpy fan have been broken for a long time, hopefully the cpu is fully working but i need to get a new cpu fan...
    I have been struggling finding one that is quality and availible now... Do anyone have a webshop where i can get a new cpu fan ?
    Thanks all, mos 2.4 is so good !! (Mac mini rocks, but i want to get my peg2 in use also ;))
    [ Edited by kriz on 2009/10/17 6:18 ]
    [ Edited by kriz on 2009/10/17 6:19 ]
  • »17.10.09 - 02:17
    Mrsmile
    Posts: 6 from 2007/8/15
    here
    Ebay Link
    and
    http://shop.ebay.de/items/?_nkw=Zalman+ZM-NB32K&_armrs=1&_from=
    very good
    [ Edited by Mrsmile on 2009/10/17 6:18 ]
    [ Edited by Mrsmile on 2009/10/17 6:19 ]
  • »17.10.09 - 03:16
  • rms
    rms
    Posts: 606 from 2004/11/27
    very good
    Does this mean that a Pegasos2 G4 can be passivly cooled? Because that's what I
    see on the linked page. Do you personnaly have your G4 passivly cooled?
  • »17.10.09 - 04:02
    Mrsmile
    No two together ...
  • »17.10.09 - 04:25
    Mrsmile
    Click to view image
    [ Edited by Mrsmile on 2009/10/17 7:30 ]
  • »17.10.09 - 04:29
    zhulien
    Posts: 139 from 2004/8/21
    why is it the Pegasos 2 G4 can't be passively cooled where some other system's G4s can? are there different types of G4s?
  • »17.10.09 - 07:24
    Posts: 12557 from 2003/5/22
    Of course, there are numerous types of G4 with numerous different max core frequencies and power consumption and heat dissipation figures each.
    Refer to:
    http://en.wikipedia.org/wiki/PowerPC_G4
    http://www.freescale.com/webapp/sps/site/taxonomy.jsp?code=MPC8XXX7XXX (G4 has 7xxx designation (integrated G4 is 86xx), only currently manufactured ones listed)
  • »17.10.09 - 09:35
    Posts: 236 from 2003/7/28
    @Andreas_Wolf
    Sure, other G4's exist. But the Pegasos-2 G4 only shipped (as far as I know) with the 7447 1GHz, which is a rather hot chip.
    I would definately recommend passive cooling. Unless you have a very large and properly secured heatsink. However, that could run into other problems such as causing too much stress on the vertical CPU card.
    Best to get a heatsink/fan to replace the stock one that is perhaps a little bit bigger, but still with fan. Copper is a good metal for the base of the heatsink.
  • »17.10.09 - 11:32
    Posts: 423 from 2005/4/9
    "why is it the Pegasos 2 G4 can't be passively cooled where some other system's G4s can"
    it can be done. my pegasos' got passive cooling on the G4. a giant bastard but silent:) dunno its type at the moment but will post some pictures later if intrested.
    zx.spectrum@3.5
  • »17.10.09 - 12:16
    zhulien
    thanks all, i didn't know there were different G4s...
  • »18.10.09 - 00:28
    @ Andreas_Wolf
    Ok, I meant active :)
    I am not sure those 1.4 cpu cards ever shipped to end users?
  • »18.10.09 - 01:19
    Gunnar "BigGun" von Boehn of Greyhound Data is a developer. I don't know about the "Pegasos 2 users" itix wrote about. Taking into account that a Free Developer Workstation is obviously aimed at developers, you are probably right that it didn't ship to end users initially. But developers can very well have sold their machine to end users by now.
  • »18.10.09 - 11:26
    kriz
    Thanks all, but very expensive shipping on the items.. I will find some with cheaper shipping :)
  • »19.10.09 - 14:24
    koan
    Posts: 303 from 2005/11/21
    I am using an SNE heatsink and fan:
    http://www.sne-web.co.jp/mwf404.htm
    Check the MWF404ALCU half way down the page.
    It's actually a VGA or Northbridge cooler, fits perfectly
    and very quiet. The fan in my case and PSU fan creates more noise
    so I don't see any point in passive cooling.
  • »26.10.09 - 21:53
