AGP card for Pegasos2
    Divinity
    Posts: 498 from 2009/9/8
    I need to connect an AGP card ATI 9250 256Mb to my Pegasos2@G4 for MorphOS 2.4.
    I'd like to know if I can use this one (I remember something about 3.3V and 1.5V trouble):
    SAPPHIRE ATI RADEON 9250
    code graphic card 11046-01-20R
    url:
    http://www1.sapphiretech.com/en/products/graphics_overview.php?gpid=59
    http://www1.sapphiretech.com/en/productfiles/59brochure.pdf
    thanks
  • »24.10.09 - 15:02
    Korni
    Posts: 473 from 2006/2/23
    Yes you can. All Radeons supported by MorphOS 2.4 fit well. Pegasos2 has an universal AGP connector, so you can't physically plug card with a diffrent than supported voltage (assuming that card is properly keyed, but every should :) ).
  • »24.10.09 - 20:45
    Divinity
    thanks.
    In the brochure It's written : "compatible with AGP 2X (3.3V), AGP 4X (1.5V) or AGP 2X/4X universal slot", so I think It's OK for Pegasos2, right ? (sorry but I don't want to damnage the Peg2 :-) ).
    thanks
  • »24.10.09 - 22:41
