Moderator
Posts: 2539 from 2003/2/24
Useing both sockets is not advised.
Useing RAM not tested for Pegasos is also not advised.
But .....
Sometimes the board won't get the wright settings after a RAM-change and you could try this:
Remove all RAM
Power on your Peg
Wait a while
Power down
Insert RAM
Try your luck
Run "memtext extensive" a few times, if it doesn't fail you stand a good chance of having a working system.
