USB -pci on Peg2
    npanag
    Posts: 8 from 2008/7/17
    Hello people!!
    I just poped in to ask a rather generic question.. I intend to buy a pci usb 2 card for my peg2 and i need to know if there is any limitations on the chipsets or if there is a list of compatability of usb cards i can check in order to buy something that i wont throw away!
    Thank you in advance!
    Nikos
    Pegasos II G3/600 Mhz + MorphOS 2.1
    EFIKA MPC5200/400Mhz + Debian Linux
    www.amigaplanet.gr
  • »22.10.09 - 07:55
    Jambalah
    Posts: 820 from 2008/3/30
    Hello Npanag!!
    USB cards with VIA VT6212L chip should work. Some Trust USB cards have it onboard.
    I'm using a D-Link Su-520 (4 external port + 1 internal) and it works great.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »22.10.09 - 09:50
    npanag
    Thanks Jambalah! I will try one with this chip.
    They are extremely cheap anyway.!
    www.amigaplanet.gr
  • »22.10.09 - 11:09
    xyphoid
    Posts: 870 from 2008/7/11
    bump! wrong post!
    [ Edited by xyphoid on 2009/10/22 12:02 ]
  • »22.10.09 - 11:20
    Daff
    Posts: 247 from 2003/4/5
    I have reviewed a USB 2.0 card under Pegasos/MorphOS : http://obligement.free.fr/articles/cptvusb20-5.php
  • »22.10.09 - 11:45
    npanag
    will do that of course :-)
    www.amigaplanet.gr
  • »22.10.09 - 11:46
    Posts: 33 from 2003/6/17
    recently I bought a PCI USB card with a NEC-Chip, which is more recommended.
    http://cgi.ebay.de/USB-2-0-Controller-HUB-PCI-Karte-5-Port-NEC-CHIP_W0QQitemZ160350324586QQcmdZViewItemQQptZDE_Technik_Computerzubeh?r_Kabel_Adapter?hash=item25559fc76a
    It is about 10 times faster than the internal!!!
    Regards
    Robert
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »22.10.09 - 15:31
    Jambalah
    ...ehm... checked my usb card.... =)
    It has NEC chip. Don't know why I thought it was the other one...
    Sometimes I buy pci cards just to test them and I guess I did the same with th D-Link, In fact, I remember that it didn't work with older Poseidon version but fine with Linux. Chris Hodges made a good work...
    Thanks Grooves for this tip!
    Pegasos II 1 ghz
  • »22.10.09 - 16:03
