eSATA/SATA PCI card available for PegasosII/Morphos2.x ?
    nexus
    Posts: 14 from 2009/4/24
    I wonder if there's an appropriate SATA-PCI card available which allows to use SATA-Devices and eSATA-devices with MorphOS/PegasosII?
    Any hints?
    Thanks,
    nexus
    [ Edited by nexus on 2009/9/16 11:32 ]
    Dye 'em black!
  • »16.09.09 - 08:22
    analogkid
    Posts: 719 from 2004/11/3
    IIRC there will be a SATA-chipset supported by a coming version of MorphOS. But until then you could use a cheap IDE-SATA-Adapter on the Pegasos. Don't think it will make a big difference in MorphOS with many small files.
  • »16.09.09 - 09:02
    nexus
    A IDE-SATA Adapter maybe does not work in my case, because I'd like to connect an external eSATA-device to my PegasosII.
    Anyway, thanks for the response!
    nexus
    Dye 'em black!
  • »16.09.09 - 09:05
