MorphOS Widescreen configuration problems
    BalrogSoft
    Posts: 171 from 2006/10/6
    Hello.
    I have a widescreen samsung monitor that i use with my Efika and a Radeon 9200P with 128mb graphic card, the problem is that while i was installing the new MorphOS 2.3, it appears at native widescreen mode for my monitor 1360x768, but this resolution was not available after installation, and all my tries to modify monitor screen modes, i can't get a sharp image as native resolution. I tried to see monitor preferences with MorphOS installtion image, but this resolution don't appear. Somebody had problems to configure a widescreen monitor?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »20.08.09 - 17:53
    Posts: 1090 from 2004/9/23
    Check the drawer sys:prefs/presets/monitors for the monitor you are using and delete that file.
    It contains all modes available for the display device. It may be possible that the stored file is not valid. It will be recreated after reboot. If you are unsure about its name check env:CyberGraphx/RadeonMonitor file. It contains the name used to store the information.
    Geit
    [ Edited by geit on 2009/8/20 22:13 ]
  • »20.08.09 - 18:11
    xyphoid
    Posts: 870 from 2008/7/11
    I also had an issue with hazy resolution it may be due to a high Hz for eg 1024x768@60Hz in bootmenu
    fine, but 1024x768@74Hz produced slight haze making date and time slightly blurry
    posted with owb 1.3
    [ Edited by xyphoid on 2009/8/20 16:30 ]
  • »20.08.09 - 18:26
    BalrogSoft
    I will try to delete monitor file, i forget that when i bought the Efika, it came with MorphOs 2.2 and a different graphic card, it was an ATI 9200 also , but was another model with less memory. Thanks.
    [ Edited by BalrogSoft on 2009/8/20 23:51 ]
  • »20.08.09 - 19:49
    Hawk
    Posts: 204 from 2003/12/29
    I have a related problem...
    I have a Panasonic Viera HDTV (Full-HD) and I want to use WXGA resolution, which should be 1366x768. My Efika has a Radeon 7500 graphics card connected to the TV via VGA.
    I added a new monitor for my TV (TH-32LZ85), 31 KHz -- 69 KHz 59 Hz -- 86 Hz
    and then tried to add the proper resolution.
    I managed to add a 1368x768 resolution at 60Hz, but it's not displayed "wide". It seems like it packs the signal in a smaller horizontal resolution, although the TV says it's WXGA, not XGA...
    It may be a problem of the graphics card, a Radeon 7500, but I read that it should support WXGA.
    Any idea?
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »26.08.09 - 14:52
