Pegasos extra hardware
    CountRaven
    Posts: 566 from 2007/12/10
    I will soon buy a Peg1 and I am thinking of adding some extra stuff on it.
    I wonder if there are any TV cards that would work under MorphOS. I do not know if there is any native support but am thinking that -just like linux- perhaps there would be some specific chips that would be supported, so if a TV card is based on a specific chip would probably work. I recently came across a wonderful external usb tv card by Pinacle any chances for similar devices to work via the usb protocol -without drivers I doubt but you never know-.
    Any sound cards? I have read that many of you have plugged SoundBlaster Live cards.
    Please share some info or guide me to similar threads.
    Thanks!
  • »13.05.09 - 09:43
    Posts: 12521 from 2003/5/22
    Yes, there are. But thanks to Articia S, overlay functionality with a PCI TV card is only possible using a PCI graphics card.
    > I [...] am thinking that -just like linux- perhaps there would be some specific chips that
    Yes, you have to take two things into account: the chipset and the tuner. Both have to be supported, see http://visionary.cybergraphx.de .
  • »13.05.09 - 11:17
    analogkid
    Posts: 715 from 2004/11/3
    If you want to add some extra stuff to your Peg1, i would suggest you get a USB2.0-Card, because the board itself only contains 2 USB 1.1-Ports. And hopefully, with the coming MorphOS 2.3-Update all problems regarding USB will be fixed.
    A SBLive is nice, it has a better quality regarding the sound. With the onboard sound, it's the only soundcard supported under MorphOS (on the Pegasos).
    If you are interested in connecting SCSI devices (e.g. a flatbedscanner or a backup-system) , a SCSI hostadapter would also make sense, there are a few models supported, mainly with Symbios 8xx chipset.
    [ Edited by analogkid on 2009/5/14 7:42 ]
  • »14.05.09 - 04:41
    Posts: 140 from 2003/9/16
    erroneous post
    [ Edited by FrankBrana on 2009/5/15 14:28 ]
  • »15.05.09 - 12:22
    xyphoid
    Posts: 870 from 2008/7/11
    going back this post, is it possible to use any usb tv tuners? pinnacle was mentioned and I have a 801e SE 1102 HDTV. couldn't locate the chipset or support, but is there a program, or a work around, and as for poseidon binding it and something like visionary v0.24 picking it up? Maybe I misunderstand the concept, but I'm just thinking ahead to a morphos macmini implimentation.
  • »30.06.09 - 14:48
    CountRaven
    A kind of support for USB TV Card will be GREAT!!!!!!
    If a specific chipset is supported via USB then I will sure buy the hardware.
  • »30.06.09 - 20:09
    MarK
    Posts: 641 from 2004/1/25
    well, if there will be a software usb-digi-tv-stick, i'll pay, say, 30 euros for that... :) (and for the hw)
    bye, MarK.
  • »01.07.09 - 13:12
