Which memmory types supports PegasosII ?
    liquidbit
    Posts: 407 from 2003/10/12
    Hello,
    I purchasing a new PegasosII G4 1GHz.
    My question is which memmory modules should I buy?
    1.SDR SDRAM geheugen / 512MB PC133 SDRAM ECC Registered CL3 (Kingston)
    2.SDR SDRAM geheugen / 512MB PC133 SDRAM (CAS2, Kingston)
    Does PegasosII supports DDR or Rambus Memories??
    Please help...
  • »14.10.03 - 23:28
    BatteMan
    Posts: 287 from 2003/2/24
    Pegasos II accept only the DDR memory...
    For a Pegasos I, take a SDR Registered.
  • »14.10.03 - 23:57
    Posts: 154 from 2003/4/22
    Pegasos II should support every DDR starting to 266.
    Then DDR 33 or 400 should work too.
    However, I'm sure some test will be done by the first resellers who
    will got it.
    MorphOS Rulez !
  • »15.10.03 - 14:43
