Pegasos 2 main board + Cpu 750 CX module
    ozkano
    Posts: 14 from 2009/5/7
    hi, a few months ago my pegasos cpu module was broken and I purchased pegasos 1 cpu module from ebay, the point is, cpu did not work, is there any solution
    best regards :-?
    [ Edited by ozkano on 2009/5/7 5:48 ]
  • »07.05.09 - 00:48
    ozkano
    bord revision 2B1
    Cpu revision 1.0
  • »07.05.09 - 00:56
    MarK
    Posts: 641 from 2004/1/25
    well, peg1 and peg2 cpu modules aren't compatible... so the solution is to buy a peg1 board or peg2 cpu... or send the broken cpu module to bplan, and let it fix...
    bye, MarK.
  • »07.05.09 - 02:57
    ozkano
    I talked with bplan, fixing price is a little bit high for me , so I am looking for a new cpu board
  • »07.05.09 - 03:15
    TrevorDick
    Posts: 130 from 2005/10/12
    @ozkano
    I'm sorry about your CPU troubles. As a matter of interest what was the repair price that bPlan quoted?
    TrevorD
  • »09.05.09 - 05:37
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 11.06.2011 - 08:35 ]
    Pegasos2 G3, 512 megs RAM
  • »09.05.09 - 06:08
    Posts: 1076 from 2004/9/23
    AFAIR you can use a Peg1 CPU in a Peg2 by setting some jumpers on the board. A friend did that on a PowerDev Meeting a while ago.
    Axel Knabe also repairs CPU modules, as long as not the CPU has been burned.
    http://www.knabe-bueroservice.de/
    Geit
    [ Edited by geit on 2009/5/9 14:40 ]
  • »09.05.09 - 10:39
    analogkid
    Posts: 715 from 2004/11/3
    Geit is right, the Peg1 has a different FSB clock than the Peg2 (100 vs. 133 Mhz), so the multiplicator-jumper must be changed (6x on the Peg1, 4.5x on the Peg2).
  • »09.05.09 - 10:51
    stephen_robinson
    Posts: 746 from 2007/4/22
    Cool to hear that they are active enough to be working and responding to emails.
    Hope so, they've got my Peg II for fixing!
  • »09.05.09 - 12:10
    ozkano
    bplan also replies my emails but I asked phone and told me, 200euro for board + 200 euro for cpu + shipping
    what my 750 CX settings should be I tried
    mine was the second position jumper layout and I switch to first but still no screen appear
    [ Edited by ozkano on 2009/5/9 18:46 ]
  • »09.05.09 - 13:45
    ozkano
    please help me, i am still waiting
  • »17.05.09 - 18:40
