Where to get hardware to run MorphOS?
    samalex
    Posts: 4 from 2009/2/25
    This might be a silly question, but where the heck can I find a system to run MorphOS? EBay is generally where I find older hardware, but there's no EFIKA or Pegasos system on there. Also the genesi-usa.com website has no place to purchase hardware directly.
    How's the simplest way to get hardware that MorphOS will run on?
    Thanks --
    samalex
  • »25.02.09 - 18:35
    Nitro
    Posts: 106 from 2003/8/24
    I just got another from Directron two weeks ago they should still have some.
    http://www.directron.com/efika.html
    [ Edited by Nitro on 2009/2/25 20:45 ]
  • »25.02.09 - 18:44
    samalex
    Hi Nitro,
    Thanks for the reply. I looked at a few hardware vendors like newegg with no luck, but I didn't think to check the smaller shops like that. I did find one also at AxionTech, which is just a couple of hours drive from me.
    http://www.axiontech.com/prdt.php?item=79327
    As for a case, I read a few places say the layout isn't mini-ITX compatible, so what type of case will work? Outside of that it looks like a standard ATX powersupply and IDE HD will work with it.
    I really want to try out Morphos but given it won't be a primary system or probably even something I use alot I'd rather not drop tons of cash into it.
    Thanks for the info and take care,
    samalex
  • »25.02.09 - 19:59
    Simon
    Posts: 809 from 2008/7/6
    I have this one :
    http://www.efikaz.eu/
  • »25.02.09 - 20:23
    Posts: 2732 from 2003/2/24
    samalex wrote:
    Hi Nitro,
    Cool, I didn't know about that one. Did you find anyone else?
    Maybe we could compile a little list so people won't have to search?
    Case? Who needs cases? ;-)
  • »25.02.09 - 20:52
    ausPPC
    Posts: 543 from 2007/8/6
    I still have a number of Efika systems for sale. Currently I'm in the process of making a completely silent system that uses a 16GB compact flash card instead of an IDE harddrive. This is the system -
    [ Edited by ausPPC on 2009/2/26 9:02 ]
  • »25.02.09 - 21:01
    samalex
    I don't mind building a system from scratch as long as I know where to get the parts, but unfortunately MorphOS and even AmigaOS run on hardware that's not easily found. I could see a 'kit' computer being made available with the Efika motherboard, case, and MorphOS... it looks like everything else can be picked-up from spare parts around the computer shop.
    Being a computer junkie and an OS whore I'll probably save-up and get the parts to build a system to run MorphOS eventually now that I know where to get the parts.
    Also just a side question, is the application support there enough to run MorphOS as a primary system? Given there's a decent web browser, email client, word processor, etc I can see this being Yes, but just curious if anyone does use their Morph system 100% of the time.
    Take care and thanks for the great info.
    samalex
  • »03.03.09 - 14:15
  • ASiegel
    Posts: 1397 from 2003/2/15
    @samalex
    https://www.genesi-usa.com/store/
    Genesi sells pre-build EFIKA OpenClient systems to end users directly via their website.
  • »03.03.09 - 15:32
    Posts: 2094 from 2003/6/4
    samalex
    Depends on waht you want to do. I use MorphOS privately as main system, but not exclusively (there is also Win, Linux and OS X).
    Best current browser is OWB. That one does really a alot, but still things like flash or a video plug in are missing. Java applets don't work (no JVM available), too (but fortunately I haven't seen Java applets since ages out there).
    Word processing is generally rather poor, however there is a nice DTP package (pagestream) and you may use google docs with OWB.
    Mailing depends, if you use POP3 then you don't have much of a problem and may chose either simplemail or YAM (they are both good and I use them as my main mailers). SimpleMail does support IMAP too, but a bit limited.
    I use MorphOS as media center in my living room (music and vids), for mailing, surfing my usual sites, do some IRC, read pdfs and so. Also I use some gfx apps and occasionally I try to program this and that, use some audio apps, edit some html or play a game. That's all fine with MorphOS.
    Office stuff I do with my other systems only and I think the mixture to have several systems around is quite relaxing. I use whatever and whenever suits my needs best. Often this is MorphOS, but I have my other systems for a reason.
  • »03.03.09 - 15:33
  • ASiegel
    @ samalex
    http://www.directron.com/efikakit1.html
    Directron is selling a kit that consists of an Efika mainboard, a fanless PSU and a fitting case (non-standard size). At 175 USD, it appears to be very affordable.
    MorphOS is not included but it should not be too much trouble to download and copy it to a USB pen drive on your own.
  • »03.03.09 - 15:40
