Printer bidirectional communication
    Posts: 66 from 2003/10/5
    Hi all,
    not sure if it can be thought better as a software
    or hardware topic, however...
    I'm attempting bi directional communication with a
    printer with no success (what that means ? Simple, I
    send the printer some command which implies a reply,
    that's really low level, technical stuff, don't care
    of it... ;)
    I firstly tried with an UPAR: assign created with
    the port-handler, either connecting the printer to
    the parallel port (via parallel.device) then connecting
    it to USB (via usbparallel.device). No reply, wait
    forever.
    Then I went the low level way using the device
    read and write commands: with the parallel port
    the read command returns -3 (unsupported command).
    Oh well... so I searched the web and found that
    Pegasos parallel port is stuck to uni directional
    mode. Is that true ? Well, at least 2+2 makes 4
    (a sad 4, I would say).
    Doing the same with the printer connected to USB
    and using the usbparallel.device, the read command
    never returns. I assume my communication protocol
    is correct (even if taken by reverse engineer a
    PC port sniffing...). Should I think that
    usbparallel.device is some way broken too ??
    I need know that, because atm I can't figure out
    until which point it's me and until which it's the
    hardware/OS failing.
    (My config is PegII with MOS 1.4.5)
    Thanks for any in-topic hint and answer!
  • »25.10.08 - 15:10
    March
    Posts: 91 from 2003/7/30
    You should try to get in touch with Sonic. AFAIR he played a bit with Pegasos parallel port and even made his own device for it that was supposed to be better that the standard parallel.device. port-handler does not support reading at all (well, this will be fixed in the future). No idea about usbparallel.device. Maybe you should try to contact Platon about it.
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »25.10.08 - 17:45
    March,
    Already contacted, still no reply. I assume he's busy or
    outdoor.
    I also tried the port-handler (68K) by Stephan Rupprecht
    which was supposed to work well but the behavior is
    identical
    Ehr... yes, surely... even if I preferred he had ended
    up in this thread sooner or later :o)
  • »25.10.08 - 18:23
    Posts: 3311 from 2003/3/5
    Afair MorphOS' parallel.device only implements enough for common printers to work and nothing related to bi-directional communication.
  • »27.10.08 - 05:29
    Posts: 408 from 2004/7/15
    Reviving the topic...
    I managed to get hold of old but good LaserJet 4 Plus. It has a parallel port and can provide status to the computer. So far i've got a testbed...
    iPod, iBook, iMac,... iRobot?
  • »13.02.09 - 05:04
