EFIKA AGP Problem - Will not power on with AGP card in.
    jclausen
    Posts: 25 from 2004/4/17
    I have a new EFIKA that I just received today.
    When I install my HIS ATI Radeon 9200 video card in the AGP slot, the EFIKA will not power on. I have also tried my Radeon 7000 that I know used to work with my Pegasos II, same results.
    The unit will power on fine with a PCI Voodoo 5 and will also power on with out video and just the AGP riser installed.
    Anyone have any ideas?
    Thanks in advance for the help,
    J
  • »10.02.09 - 17:13
    Simon
    Posts: 809 from 2008/7/6
    Riser faulty ? And apparently it only goes wrong when a card is inserted ?
  • »10.02.09 - 18:09
    jclausen
    Get this!
    Problem was with the power supply I was using.
    Nothing wrong with it at all, just not compatible I guess.
    460 Watt that I pulled from my overclocked Q6600 - worked fine.
    The only reason I replaced it was to get power supply with a 120 MM fan.
    I pulled out an old no-name brand and it worked fine.
    The power supply that didn't work was a Cooler Master
    Thanks
    J
  • »10.02.09 - 18:57
