April-Fix questions
    CountRaven
    Posts: 566 from 2007/12/10
    I want to buy a Peg1 mobo as I miss the good old days with 1.4.5 in my old Peg1. Have found one with April 1 fix.
    What are the differences between boards with April 1 fix and the ones with April 2 fix? Basically what are the differences between the 2 fixes?
    Will I find some serious issues/ problems in the board with April 1 fix?
    Got an efika as well should post first impression here soon.
    The goal is to have in my home eveyr machine capable to run our mighty OS.
    Long live MorphOS.
    Fixed typos in topic
    [ Edited by hooligan on 2009/1/30 8:14 ]
  • »30.01.09 - 00:14
    jcmarcos
    Posts: 1178 from 2003/3/13
    I recall this information is in the amazing "Pegasos Book".
  • »30.01.09 - 07:48
    CountRaven
    Except the references to the big Peg book it would be good to have some opinions from users owning an April1 fix mobo. Mentions problems and issues etc...
    Until I get home from office to take a look on the big book it will be cool if someone could make a little summary of the differences.
  • »30.01.09 - 09:00
    CountRaven
    Checked the Pegasos Book, on the Peg1 mobo specifications section but there is no mention about the differences between the two fixes (1 or 2).
  • »30.01.09 - 09:49
    Posts: 2728 from 2003/2/24
    IIRC the April 2 was a more tuned up, second try to get the G4 working reliably with the Articia S. I think most important stuff was in the April 1 already? Anyway, the big difference was going from "April 0" (no april ;-)) to April 1...
  • »30.01.09 - 15:41
