Posts: 1178 from 2003/3/13
pan1k wrote:
I'm thinking of mounting my Efika in a Mini ITX Case.
Ummm... Unnecesarily big, in my opinion. It provices space for peripherals you can't connect easily to the Efika.
People have put the Efika inside much smaller cases (external CD-ROM enclosures), albeit with some work. Notable case is
Geit's, but there's a lot more, including using the same cardboard box the Efika ships in.
All in all I think I will come out ahead, rather than buying the Genesi case...
...but the Genesi case is very nice, and tailor made for the Efika. Are you sure that ITX case you refer is cheaper than Genesi's?
